Hello all.
My 59 johnson 10hp has had a full tuneup. New ignition parts, carbs cleaned and rebuilt, plugs and fuel lines. Pulled it bout three times and she started right up. Now I need to adjust the carbs. I have read stickys post on carb adjustment. Set needles to advised positions. The motor seems to idle fast. If I turn tiller down lower then the shift mark, it dies (idle too slow). Tried to adjust carb (slow speed needle) to sync with slower idle better. Can't get it to idle down. Adjusted cam under flywheel. Not really helping. Should I have the motor completely parallel to the ground when adjusting carbs? It tilts a bit when in the water bucket. Maybe affecting the float? Also should I adjust this in neutral or in a forward gear? Frustrated. Any advice would b appreciated.
Thanks in advance.
Thanks in advance.
