I recently disconnected my vro in the same way described above. I have a 96 200 johnson, I ran it in the river for the first time and got about two miles and it slowly died down and shut off. It would crank back up then shut off.
My question is aobut the fuel restriciton buzzer. My alarm beeps when I turn the key on, but in the 7 years I have had the boat I don't ever recall the buzzer going off. I pulled the hose of the top of my fuel pump and turned the motor over fuel pumped through, but it seems like it was a little weak. When I fast idle it I get some popping in the carbs. Which we have been thinking was weak fuel. But if I have a low fuel buzzer shouildn't I hear it. I have tried pumping the ball while its idling with the fuel cap open and it doesn't seem to make a diff.
I just had a no good boat mechanic put this thing back together and trying to figue out his mess. So, it could be any number of things.
I have a repair manual now and am trying to figue things out. This has been one of the best motors I have owned until this series of unfortunate events.
To reiterate my questions, how do I know my fuel pump is pumping enough fuel, and if my fuel restriction alarm is working?
Also, if I wanted to replace my vro with just a fuel pump, can anyone give me a part number. I can't find them without the Vro.
