Telltale what is the tell?
TheHawkMan
Just installed lower units on 200 merc outboards twins.
Running on muffs first climbed to 140 degree but water was pumping well from telltale. Seemed a little hot for just 5 minutes.
Second, no water right away from tell tale, pooked hole seemed to be clogged got a dribble, reved egine got more water, motor climbed to 180, shut off.
???? Plan to drop lower unit and check impeller and pull thermos. Should/ how do I clean water passages/ heads if full of crap? Is it possible that they are clogged?
Motors are 1996, ran last year no issue over heating, do run in saltwater.
j_martin
Re: Telltale what is the tell?
Engines are so light and have so much fire in them that a 30 second warm up is pretty normal. Engine #1 is functioning as it should.
Engine #2 needs a water pump.
Water pump inspection and minimum replace impeller should be an annual thing.
hope it helps
John
