Is this engine worth anything as far as rebuilding it? Found the add on CL when looking for a engine and outdrive for my boat. Here is some of what it says.
And here is the add
http://portland.craigslist.org/clk/boa/2265051365.html
It has a 224 cubic inch 4 cylinder aluminum engine . So the engine's weight wont slow you down, but it also has a mercruiser cast iron head (serial #6921075) on it that boosts the horse power up to 175, which is good for a 4 cylinder. But it does have a blown head gasket that will need to be repaired. And it doesn't only use fresh water to cool it down but it also has a radiator so if you take it out into the ocean the salt water wont damage things.
And here is the add
