stevo10081984
- Jan 16, 2011
- 40
ok i need a little guidance, i just replaced the thermostat, i ordered a gasket for the water cover, it came with 2 i was told to use 1...now its leaking, my question is what should i do?...is there a sequence to tightening the bolts?, and what torque? my shop manual is useless to me...im going to go rent a inch lbs torque wrench, as mine is only foot lbs...hopefully some will chime in, also i have some gasket shellac kicking around somewhere should i use it?
