Re: Is this how the floats should look?
Before you add the float bowl, turn the carb upside down and gently blow into the fuel inlet fitting. If air passes you have some work to do as the needle and seat are not closing. Either they are bad, hung up, or the float is misadjusted. If you can't blow through the fitting you are good to go.
