1993 Mercruiser I/O cracked block
dmpick
Would anyone know what else :( :( would cause the block to crack if boat was winterized?
crazy charlie
Re: 1993 Mercruiser I/O cracked block
Boat could have been winterized but not correctly.Thermostat must be open to winterize block properly.Block could have been cracked before it was winterized if the boat was not winterized early enough.Severe overheat could do it too.Did you winterize it yourself????Charlie
What Motor ???????<br />Where's it Cracked ??????
