Re: Trasom & Stringers
rot can occur anywhere moisture (fresh water) contacts wood. There are a million ways that can happen, and the cause can range from neglect to defect. Some boats, by design, have greater risk by greater opportunity for water to accumulate, and not drain. Even a small undrained pocket in an otherwise well maintained boat can get it, as can a small opening, such as at a motor bracket where the seal has failed. It can occur in the wood backing to a dashboard, which is important b/c it supports the steering wheel.
I believe that no cover is perfect, so I believe draining is most important--that means the plug out on the trailer, pump working while moored. The cover and how it's parked is second and third. I have never understood how a boat could hold water on a trailer, when draining it is as basic as tying it to the pier when it's moored.
