bassaddict1
- Mar 11, 2011
- 1
While servicing my power trim assembly I inadvertantly forgot to remove the anode prior to removing the trim assembly from the bracket. After servicing and re-installing, the motor started then instantly stopped. I hear the solenoid clicking which tells me that either I have a bad ground or the motor is shot. The service manual mentions noting the position of the ground strap. Needless to say, since I did not remove the anode this step was missed. Where exactly is the ground strap located? Could this be the issue or could it be more serious? Any help would be most appreciated.
