Re: 125 head replace
Well, I'm guilty for not fully thinking aboout whether or not a 125 was made in that year. However, ANY Force three or four cylinder block from 90 to 120-125 will physically bolt to the match plate. As I said, with later model Force engines where Mercury started making changes, the control cables and linkages may be different.
Do not be set on the 125 block: The 120 was actually a better engine and will give equal performance. See: the 120 is a big bore, short stroke engine while the 125 is a small bore long stroke engine. BOTH are set in the same block.
