Re: 1998 Johnson 150 Ocean Runner OIS
Id check the whole fuel system...make sure no debris in the tank...empty it out, clean it out, make sure no leaks along the system..replace the fuel filters.
try it again, if it wont throttle up try pumping the bulb...see if that helps
how long has it been since you rebuilt the carbs???
thats a complete tear downa nd cleaning of all parts and passages , all new gaskets and replacebale parts that come in the carb kits....dont over tighten the carb bowls...they are plastic and can warp easily.
but i wouldnt jump right into the carbs until you checed a few other things out...
wondering why it would rev ok in neutral( still using more fuel) but dies when in gear...
Id make sure you know you ahve spark in all cylinders....while you are at it...
you could go ahead and check compression ...then come back
good luck
bob
