I am trying to remove the outer exhaust cover located behind the CDI. There are 25 bolts, and I broke the 4 in the middle of the cover. The other 21 are ok. The cover is stuck on because the 4 center bolts that broke (whats left of the studs) are siezed to the cover. I have tried to carefully pry the cover off. I have used a soft hammer, and PB blaster on the stud remnants with no luck. Any suggestions on getting this cover off undamaged? Also when I reinstall the cover since all perimeter bolts are sound can I reinstall the cover without the center bolts, or will an internal cover leak cause water intrusion to the pistons?
