SalmonSlayerr
- Mar 1, 2011
- 24
Hello, I have a 1990 6hp Evinrude Model E6RLESR... I just did a compression test on it and both cylinders read around 90 psi.....Does anyone know what the compression should be? is 90psi good or bad? It wont idle and I just pulled the carb off and check all the ports.... all where clear and float looks clean.....Currently wait on the carb kit to show up in the mail. It would run at a high rpm but not a low rpm....at the high rpm it will kinda back fire??? anyone know what coul;d cuase this and if my compression is good at 90 psi?
