Typical love story got a good deal from a friend. The motors in tact, boat was dam near underwater. The fuse box is rusted out, obvously this killed most of the wire conections thru out the boat. I've been chasing wires and check leads for about a week. Reading countless blogs here and a few library books that got 25% of the way.
Two biggest questions I'd hope you guys might be able to help with:
1. The ignition system is a mess. The keys missing its been tampered with in side the throttle lever box. What wires do i need to start this boat. I see that theres the red harness that hold everything. What leads do i need to wire to a switch to 'hot wire the boat'. Is that my best bet for starting this thing up?
2. Fuel pump. I've searched high and low for this rebuild kit with NO luck. The inside of the pump has an M above the numbers '335333'. I even went to West Marine. No one seems to carry this? On the Iboats site it only has 78-up 115 hp.
I took the pump apart the screen was full of sediment i cleaned it, put it back together primed the fuel and shot fuel EVERYWHERE!!!!!! Could be due it improperly putting it back together. The Clymer manuals I have don't show very much of how to rebuild it.
Thanks for any leads you can give me on this. I'm getting to be at a dead end with this resurrection!
