1999 Bayliner Capri with 3.0L Mercruiser that has cracked head/Block Need Help
Ravens9273
I just bought a 1999 Bayliner Capri today that has a 3.0 4cyl 140hp engine with either a cracked head or Block.
I was looking at engines and see many for sale coming from 1987 or 1988 years.
I have not seen any around the year of the boat I purchased.
I have been told the 87 or 88 3.0 will fit my boat as well as also will not fit.
Wanted to know if anyone here knew what year engine's would fit.
I am also unsure at the moment if it is the head or the block that is cracked.
If the head is cracked I have found a 87 3.0 engine for a few dollars that is seized but the heads are good. Would the heads work from this engine?
Thanks for anyones help. I know nothing about these engines and this is creating headaches on what to buy. I am trying to avoid an outrageous cost in repalcing a new engine etc....
Re: 1999 Bayliner Capri with 3.0L Mercruiser that has cracked head/Block Need Help
Ayuh,... Any of the 3.0ls will fit, just some need abit of adapting...
Biggest difference is the flywheel/ coupler bolt patterns, but adapters are available...
black-betty
same question , will the out drive shafts fit, like are the spines the same, im doing the oposite 1987 to 1999 motor
Ayuh,... It might be the same question, but this ain't yer thread...
Please start your Own thread, about Your problems...
black-betty
why do i need to make another tread when its the exact same question in reverse?
Because this thread belongs to Ravens9273,...
And, Hyjackin' it isn't fair to Him, nor yerself...
