jayhanig
Master Chief Petty Officer
- Jun 27, 2010
- 836
Slowly but surely I'm getting my boat ready for the water later this spring but I've run into something which has stumped me.
When I bought the boat last Labor Day, I was told the tank was full. Later I had to have the transom replaced due to water coming all around my outdrive. Of course the engine and outdrive had to be removed, along with the fuel tank. After that repair, everything was replaced and the boat was winterized.
Later I noticed the fuel gauge said I just had about 1/8 of a tank. I asked the guy who pulled the engine for me what he had done with my fuel. "Nothing", he said. "The tank was light enough we didn't have to dump any." Hmmm....
The gauges were pretty flickery and some of them didn't work so I ended up getting my boat rewired and replaced the entire panel, adding on a Hobbs meter and an extra bilge pump (this one automatic). I mention all this because even with the new gauge, it didn't show much fuel. The only difference is now the gauges are rock steady.
So I take the boat to a gas station and fuel up. It took just a little less than 5 gallons before the vent started leaking a little bit of fuel and the fill nozzle started to pop off (as they do when the tank is full). It seemed odd but I'm still not putting 1 and 1 together. But when I get home I check with the fuel gauge again and it's only reading maybe 1/8th tank again.
I try poking a coat hanger down the fill opening on the transom and it comes back wet, though I'm certain I didn't get it very far in. I finally got around to measuring the size of the tank: 16.5"X17"X18"=5049 cubic inches= 21.85 US gallons.
I had thought that either the seller or the guy who repaired my transom helped themselves to my fuel or it had never been fueled up at all. Now I'm thinking the seller THOUGHT he filled it because what happened to me, happened to him earlier.
I disconnected the fuel vent and blew some compressed air through the line from the external drain and where it connects to the tank. I didn't find any obvious obstruction. The fill tubing is a larger diameter and it seems to be a little constricted where it ties in to the underside of the transom filling port. The constriction doesn't seem to be enough to cause this but I don't know what else to think. This is weird.
The tank, FWIW, is metal and appears to be in excellent condition. Anybody have any ideas?
