Re: 1965 Johnson 9.5 will not run WOT
There are quite a few possibilities. When you say it doesn't idle very well, does it miss? When running at wot for a while does it miss? Some things to try, especially if you haven't already done so on this motor.
- Carb rebuild (very easy parts are less than $30)
- Clean fuel filter
- Switch to plastic fuel tank (mine was flaking choking the fuel)
- New points/Condensers (fairly easy parts about $30)
- New fuel lines
Sounds like a lot, but on a 45 year old motor....stuff starts to break down
I got fantastic advice on here when refreshing my Sportwin, and am glad I spent the time and effort to replace all the 'wearing' parts. I think I spent close to $200 but now have a very reliable motor that I understand the workings of.
p.s. If you're going to the trouble, I'd suggest a new water pump impeller also
