hey all. im working on putting y drive back together after doing ujoints. i am stuck now however. when taking the bearing and ujoint assembly appart, four shim looking rings fell out. fine i can put them back in. but im unsure if there is any kind of order they should go in. as you can see in the picture there are 3 thin silver rings and on black ring that almost looks like a piston ring with a small section cut out so its not a complete circle. if anyone has any idea of how these go in let me know. thank you
