Help locating vintage Johnson parts supplier
wduncanjr
Hello. I have a '57 Johnson Seahorse CD-14. I need to order some parts (carburetor kit, float, impeller, fuel tank diaphragm). Can someone recommend an on-line supplier for this motor?
When I revived my '55 CD-12 a few years ago, I bought from vintageoutboard.com, but it doesn't look like they're around any more.
Any guidance is greatly appreciated!!
-William
oldcatamount
Re: Help locating vintage Johnson parts supplier
Try www.maxrules.com. I get parts for old motors from him all the time. Little pricey, but quick delivery. If he doesn't have the part you need, he'll find it for you.
babysdaddy
In addition to the above replies you may also try nymarine.com
Silvertip
Twin City Outboard (twincityoutboard.com)
tx1961whaler
iboats has a lot of the common repair items, like the carb kit, impeller, lower unit kit and ignition parts.
wduncanjr
Thanks for all of the responses!! Surely appreciate it. I'll check these out.
1946Zephyr
Here is a nice list for your future reference.
sea-way.com
engine blade and prop.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
tcoutboards.com
http://www.nymarine.ca/piclist.html Paint and decals
AlTn
WD...marineengine.com has parts and prices...word of advice as I've recently been working on a '58 10hp. evinrude...take the time to make a list of everything you need as shp/h. charges really add up quickly for multiple orders..if you discover lower unit "concerns"...check out the prices for pinion gears, shift dogs, fwd and rv gears as a used lower may be wayyyyy more appealing....any listing with "vintage" is pricey
