Merc 5.7L EFI
Problem: Computer doesn?t send power to the spark plug, so spark plug doesn?t sparkle, and engine does not start. Engine does start if we give power to it directly.
I will be glad to receive any help. Thanks!
Regarding problem, checked with computer scanner and said problem was TPS (throttle position sensor) Bought a new one, put it on, still not work, and scanner still says problem on TPS. Wait for any help!!!
Try disconnecting the battery to reset the trip code on PCM.
