ccustomrides
- Mar 3, 2010
- 70
I got my new prop in the mail 3 days ago. I ordered a Stiletto prop for my boat and got a Turbo 1 because in the paperwork it said out of stock on the stiletto model. Anyway thats fine and they are made by the same outlet anyways and from what I hear the turbo is a better prop. Last summer I ran a 21p stainless 14 1/4 dia. My boat ran great but I was a little low on the RPM. Maybe about 4200 RPM at the most. I wanted to get the 19p to get into the 4500-4800 range. I have a 200cc Sea Ray with a 4b 4.3 lx. Anyway so I get my prop and inside the box I find the prop hub kit. I used the same guy that I purchased my other prop from last spring. I look at the box and instead of the mercury Flo Torque or whatever I see Guardian on the box. So I say ok whatever they are all the same. I look inside the box and what I see is exactly what the pic shows when you type in guardian on the iboats website under search. You get back thrust washer,black hub with splines already in it???? then what I call a keeper maybe and flat washer with one side having a sticky tape side.???? So i see no nut or any other way to secure the prop on the shaft. Do I just use the keeper and the locking washer from my old setup to secure this one or do they sell one for guardian but it just dosent come in the kit. I did see one website sell a nut something else and a cutter pin for guardian. To me I hate the look of cutter pins and does my alpha one gen 1 even come with a hole in the output shaft for a cutter pin? So my question is this? Did I get screwed and it should of came with a nut and some way to secure the nut or do I need to get all of that extra jazz on my own dollar and the hub kit only comes with what you see. Will my mercury kit fit this prop. On the box it says use guardina only? The main thing i see is the built in splines inside the hub vs the insert we use on mercury hubs. So if someone can share some light on how to install this hub kit or what I am missing would be great. Also if anyone has a full diagram or instructions on how this kit gets put together that be great. I just see all kinds of stuff on the net it makes no sense because I should of got everything in the kit. Thanks.
