Re: Hello i have a 125 force but i cant find serial n model numbers !!!!!
Jesse-C;
As none of us know if the engine was original with the boat, try this and see if there is anything there. This can be used to cross reference the s/n:
Force Casting Number
The cast number is located under the ignition plate on the starboard side of the block, beside the top bypass cover. The cast number will be either a six-digit number ending in 010 or a number starting with either 800 or 818, ending with C, then a number. For example: 800-153-C6
Gerry
