Re: Ready to mount my engine.
It depends on your engine mount, but most are made with several bolt holes to allow the engine height to be adjusted up or down. I recommend you start by mounting the engine in the uppermost mounting holes. (lowest engine height) If possible mount it so that it can be moved up in to the next mounting holes, raising the engine height, based on testing you will do at the lake. ezemobee's suggestion may be a good baseline to start from, but arrange your mounting setup so that the engine can be adjusted. Ideally the engine will sit as high as possible without cavitating the prop at high load/ speed. In the right position the enigne will run more efficiently with less drag and better fuel economy. Not to mention optimum speed.
