Re: Spitting water
Mstate, Run the beast on a flusher device. If water exits the gratings above the antiventilation plate, the motor is pumping, and it is likely the thermostats have not opened. At idle speed, in neutral, on a flusher, the thermostats may never open, and you will not have a telltale.
