76 mark twain
jeremy888
hello everyone...i am new to this site and to boat ownership
i need some help with my 76 mark twain
302
188hp
mercruiser 888
i only have forward and neutral no reverse....not sure if i just need to adjust the shift cable or whats wrong. im an auto tech so i should be able to handle fixing this thing but i just dont have the info to do so.
also i need to figure out how to bleed the trim system and what oil to use.
the trim buttons dont work up front by the steering wheel and only down work at the back of the boat.
i have however used a jumper wire to run the pump up and it doesnt lift so figured it need a bleeding, since all the lines were disconnected when i bought it
please help!!
jeremy888
Re: 76 mark twain
no one can point me in the right direction? i have been trying to find some old post about shift cable adjustments but no luck so far
