2006 F115 Fuel filter between VST and Low Pressure Pump???
hawilson2
For a 2006 F115, is there a fuel filter between the VST and the low pressure fuel pump? If so, what is the part number and how often should it be changed and checked? Thanks in advance.
hawilson2
Re: 2006 F115 Fuel filter between VST and Low Pressure Pump???
bump ??? Any ideas???
99yam40
Owners manual should give the maintenance needed and how often.
And may need to look at the parts break down for your motor to see if there is one listed.
scjmc
My 115 had a fuel filter in a clear plastic bowl before the lift pumps. I dont think that there is one between the lift pumps and the VST tank.
