Re: Truck paint scheme.. what do you guys think??
It depends on what you use. The cheap option is Herculiner. 100 bucks for a gallon, rolls on. Cheap, looks good for a few months, then starts to fade and if you are runnin trails or anything and you get some rub, it will come off, especially in hot weather. If you get it professionally sprayed on with either Rhino liner or line-x, it will turn out much better, especially if you get a UV protective coat mixed in or as an overcoat. It looks good in my opinion. I say go for it.
