Re: ignition coil wiring OMC 350 5.7L
Not sure what engine and setup you have, but here is a common setup...<br /><br />The positive wires:<br /><br />One comes from the starter. This supplies the coil with a full 12 volts for starting. After the engine starts, the coil receives power from the other wire....<br /><br />The other wire is a resistance wire, (or possibly a wire coming from a ballast resistor - either way, the result is the same, a lowering of voltage). The best way to check the voltage of that wire is with the engine running. There should be a drop in voltage - I'm not sure of the ammount of drop - it seems like it goes to 9 volts - maybe even as low as 6. If you need to check it without the engine running, I believe you need to make sure that the points are closed to get an accurate reading.<br /><br />On the negative side:<br /><br />One wire comes from your distributor (points)<br /><br />The other wire (I'm going from memory here - forgive if I'm wrong) is from your shift interupt switch.
