First, I am somewhat of a newbie to outboard maintenance. My motor has no power under load in WOT, in neutral, runs fine. My question may be simple, but I hope someone with more expertise can help. If the motor is running fine in neutral, could it be a stator problem? I have changed the plugs, but wanted to input before I dig deeper.
I have rebuilt the carbs and fuel pump BUT did not check sync and timing. I am going to replace fuel line and bulb and decarb the motor and then get it linked and synced.
I am not sure if is a fuel problem or a ignition problem.
Thanks for any help.
