Thanks. 4500-5000 is what I thought. I also was wondering why so much lower then most 2 stokes. That was answered as well. Thanks-- One more Question--
Im running 4900-5000 rpms. She is a bullet out of the hole and tops out at 34 mph. I am usually up at 4500 to 5500 ft elevation if that helps. Would like to gain a little more top end. Any ideas ?
Boat set-up,engine height,prop brand,prop size,boat weight,type of hull all affect speed and handling. If your set up for skiing/tubing you will be slower than a set-up for fishing and speed.
