Where is fuel filter on 4.3 L Alpha one 205
billfred
I've got an 87 SeaRay and I was doing some winter maintenance. I was thinking of replacing the fuel filter. However I can't find where the fuel filter is.
Can someone help me out?
It's 4.3L V6 205HP.
Thanks,
Bill
Re: Where is fuel filter on 4.3 L Alpha one 205
It's 4.3L V6 205HP.
Thanks,
Bill
Ayuh,... Welcome Aboard Bill,...
If it's got a cannister style spin-on, it should be in the neighborhood of the forward starboard corner of the motor, down below and/ or forward of the exhaust manifold...
It should be hardlined off the fuelpump...
Some 4.3ls, came without 'em,... I recommend puttin' 1 on if so...
Don S
It doesn't have a spin-on water seperating fuel filter (you do need one as Bond-o suggested). the only thing you have is the filter under the the fuel pump bowl, and one in the inlet of the carb.
billfred
I haven't been having any problems with the boat. Just doing some winter maintenance.
How do I add one of these? How much and where do I get it from?
Is this really something I need to mess with. I'm assuming it's OK since it's been running OK for this long.:confused:
180shabah
Filter assy is available in the marine store, at the top of this page. The install will be pretty straight forward. Existing filters do still need changed though.
