Hello all!
I have a 1990 Johnson (70 hp) that I have owned from new and used quite sparingly and mostly in fresh water (maybe 200 hours on it or so).
It has always served me well but last summer it started "hesitating" now and then, with that I mean I am crusing along at 20/25 knots when the engine just suddenly cuts out and drops dramatically in rpm! It actually does not stop but resumes after a second or so...
I have done all the servicing on the engine myself through the years but I have only replaced the spark plugs and the oil in the gear housing every spring. I have also a water separating filter on the fuel line that also has been replaced every spring.
Anyone here that has an idea what could be causing this, I guess it could be quite hard to trouble shoot as it happens only once every hour or so...
Thanks from up by the Arctic Circle!
/Rikard
/Rikard
