I'm not a boat engine mechanic. I enjoy saltwater fishing. I'm mechanically inclined, and finacially challanged. I'm looking at a well used 24' Stamas cuddycabin that's re-powered with a V-6 Merc. I'm told it's a 1999. Seller tells me that one of the freeze plugs "fell out" of the engine late last year when he was about to set her up for the winter. He showed me the plug. It appeared to be brass, and corrosion was minimal. There was little scarring along the rim where it was pressed into the block. Oil is not contaminated. I believe it's set up on a raw water cooling loop. Seller has owned the boat two years. Prior to him trailering the boat, it was docked in brackish water. What would cause a plug to come out (not freezing weather), and since it's on the bottom of the block, and will the engine have to be pulled to get it replaced? What else should I worry about if the freeze plug just fell out?
