I have a 1992 mercruiser 3.0L in an 18ft chaparral open bow. I need to know what torque shift prop to buy. I am currently running a 19 pitch stainless ballistic prop which gives me a top speed of 45mph at 4500 rpm but the ski pulling power has dropped off compared to the 17 pitch aluminum prop that was on it previously. The biggest problem with the 17 pitch prop is wide open throttle is at 5100 rpm.<br /><br />I have the opportunity to buy a torque shift that is the 144-132 model with the zz cam. What do you recommend? I will not be able to test the prop before buying unfortunately.<br /><br />Thanks in advance,<br />David
