I have a 1996 merc 40hp 2 stroke 4cyl. How do you drain the carbs on the engine?
W willthrill Cadet Joined Oct 13, 2008 Messages 19 Feb 25, 2011 #1 I have a 1996 merc 40hp 2 stroke 4cyl. How do you drain the carbs on the engine?
5150abf Vice Admiral Joined Aug 12, 2007 Messages 5,808 Feb 26, 2011 #2 Re: drain fuel I have never worked on one but there has to be drain plugs on the bottom of the float bowl, you may have to pull an air box to get to them but there should be some there.
