I have a 1985 35 hp johnson on a 16ft aluminun boat .It only goes about 10mph,I did a compreshion test and its good 110 on all.I read a little about it and came up with its got to be carbon build up.i looked in the cylender walls and its caked.I havent been on the water yet but I have done some procedureds i have read online.I have put seafoam into cylender walls for 10 min and turned by hand a couple roatations.then with plugs out i turned it over to blow it out.then i put fresh high grade gas in gas can and added good 2 cycle oil and seafoam into fule.I then put my muffs on and ran on idle for 30 minutes.Im hoping it helps.I would like to know the top speed I should get from the 35 hp,and a 50 hp thunderboalt 1968.I have a thunderboalt i can get cheap and looking for more speed but want to know what to expect before I buy .ty.If I buy the thunderbolt i got a spar that has a bad piston and i foud out the hard and expesive way that son of a _____.he said it was the wrong prop and when i get the right one it would go faster.lol so i will never buy a motor again without checking copresion.
