i have a 1975 hy ryder tri haul boat made by hi plastic i am replaceing transom and floor in i have a couple questions
1 the stringers where completly hollow there was nothing in them at all no rotten wood or anything is this normal
2 on the transom do you put fiberglass between the two pieces of 3/4 plywood or just use expoxy resin to glue the togather.
3 when i took the top cap off the boat someone had fiberglassed the back of the cap at the transom to the bottom of the haul i had to cut it is this correct or should it be riveted
i want to thank anyone for any help they can give me
