Mercruiser 120 low top speed
ryanr623
I have a 1982 imperial 18 foot boat, that according to iboats, weighs 1200 lbs. Top speed is 24mph (GPS), at WOT, which is 3900 rpm. I figured I was over propped (19p), but i doubt that a 17p and 300rpm would make much of a difference.
Im wondering if the imperial hull design is horrible. My buddy has a newer merc 120 boat, and his weighs 2000lbs and his top speed is 35mph.
Anyone else with a merc 120 with low speed numbers? Im hoping to rule out engine problems, as i am selling come spring.
Re: Mercruiser 120 low top speed
Ayuh,.... A complete tune up, 'n compression test should sort that out,....
Otherwise, this is a Boat question, 'n Not a Motor, I/O question....
ryanr623
Suppose I should do that before i sell anyways, thanks bud! Doesn't that seem awful low to you?
Bob_VT
Try a 15 x15 Prop.
egleas84
If the OP's compression is shot what can be done? New piston rings, valves? I just got the same motor. I had a compression test and it checked out; just wondering for future reference.
Ayuh,... At that point, the motor has to be Rebuilt....
egleas84
is low top end the only definitive symptom of bad comp? I hope for the OP's sake that 15x15 prop works out :)
ryanr623
The motor was rebuilt 3 years ago, i doubt it's that. Hard starting is another, dying at idle, poor running.... all signs of low compression, and mine starts immediately and runs great.
egleas84
Guess I don't need to worry about mine either. I had an Imperial tri hull 16'er that had a messed up hull (floor was rotted to heck and all the wood weight went to one side because i never dug it out...) and that thing still did 32 w/ a 85hp OB. Gotta be pitch then...
How much did that motor rebuild cost you? DIY?
ryanr623
The guy i bought it from last year had a shop do it. He showed me the receipt but i honestly cant remember what the cost was.
steelespike
Low compression also will produce slower hole shot. Both rings and valves contribute to low compression.Bad valves will usually produce a rough idle.Other things causing poor pewrformance:
Throttle not opening all the way,poor tuneup,timing not advancing as it should.Poor hull condition,
waterlogged flotation foam.Typically a boat like that will produce speeds 35-40 mph and 4400 to 4800 rpm.
