chrismerc150
- Feb 24, 2011
- 2
this has been going on for awhile. we would go out for the day no problem then the next couple of time we would be humming along and it would just die. no warning just die. prime the bulb and off we go stop prime off we go....it would run longer in between each prime then the next time we would go out no problem then another time it would play up once..anyway finally had enough they said stator no good had that changed and one of the control modules had gone they said the whole problem was caused by a damaged wire. thought problem solved took it out worked okay running rough tach went crazy all over the shop. took it out again ran for 5 minutes died again same problem prime the bulb and off we go again...took it back after the money we have spent we throught problem solved.... they have now change fuel line even though they say all that checked before. they run for an hour and found no problems.. picking it up tomorrow and we shall see if this has finally fixed it..just wondering if anyone has this intermittant problem and finally had it sorted.
