i rebuilt carbs and adjusted the carbs 1 1/2 turns out .i put the boat in the lake run fine .turn engine off gas drips out of carbs and hard to start also prime bulb is soft.pump prime bulb back up to get engine to start.i did notice on the old needles in float bowl had rubber tips and new ones don't.does this matter.i did not rebuild the fuel pump could this be the problem
