Re: Aluminum Boat Repair
If it is a crack it is a stress area and I really don't think JB will hold it so you will need to have it welded.
It may be a small crack now but it will grow until it runs out of metal to crack.
You don't say where the crack is but I would geuss it is a transom or a seat and it really needs welded, nothing else will permamnently fix it and once you put anything else on it it makes it really really hard to weld.
I have welded aluminum for 23 years and have tried to weld both JB and caulk, it is next to impossible.
What you want to do is take it to a welder and have him drill a small hole right at the end of the crack then weld it, the hole will stop the crack from running anymore, yes the crack will run after it is welded if your guy doesn't get it all, drilling eliminates that problem.
