175 Johnson outboard trim oil fill
twostroke87
Re: 175 Johnson outboard trim oil fill
there is a plug on the front of the ram set, you need to remove that to fill it.
Make sure the engine is trimmed all the way up when you open the cap.
DOStafford
there looks to be a plug beside the ram set, on right, there is a screw in it, oil drips out?? is this it??
jonesg
Hopefully you set the tilt lock on the outbard before putting your hands under there.
