donaldboyer
- Oct 15, 2010
- 26
Hello!!
Mercury 90hp
1988
s/n 0b312461
Recently had our boat on holiday for a couple of weeks and part way through this time a problem started with the motor. Wouldn't idle very well...
Symptoms: Motor stalls at random times (2 - 3 times per min) when at idle (in or out of gear), and needs plenty of throttle to restart again.
When it is running at idle every few seconds or so it does a funny thing thats hard to describe... kind of sounds like on cylinder gets an extra bit of "oomph" and revs jump every so slightly (maybe 50 - 100 rpm) for a second or two then settle back at 900rpm. Then it'll do it again after a few seconds (maybe 7 - 10 secs between), and thats if it doesn't stall!
At revs, this motor runs perfectly.
Idles at 900rpm in water
Has fresh fuel.
Used a can of Power Tune in it less that 12 months ago
Motor was fogged for winter
Battery is less than 12 months old
Motor is producing over 13v for charge
So I'm not sure what to do about this. I haven't touched anything so far.....
Any advice??
Donald.
Mercury 90hp
1988
s/n 0b312461
Has fresh fuel.
Any advice??
Donald.
