Mercury lemon?
blkcloud
3 years ago I bought a new 22' deck boat, with a new 175 optimax.. ran like a top, at the end of the season I got into some shallow water and sucked some gravel into my motor, I took it back to the dealer and they cleaned it and put in a new waterpump.. I took it out and between 1000 and 2200 rpms the port side (i think) of the motor will get hot and the alarm will go off.. we hooked a digital gauge up while in the river to see the temps. I have since in the last 2 years had no less than 4 water pumps put in, the whole motor has been completely tore down twice looking for a blockage..the dealer has called mercury and did everything mercury told them to do, they even put a pipe inside a pipe to increase the water pressure, which it did,, it has a really strong stream coming out of the motor.. but it still gets hot.. and the bad part is.. the rpm range is where I run almost all the time while dragging my kids around on a tube.. today I called the dealer and mercury instructed them to fabricate a scoop or funnel or something like that, that fits on the foot so more water will be directed into the motor.. they are going to test run it Monday.. have any of you ever heard of this problem before? thanks!
j_martin
Re: Mercury lemon?
Have you checked into the possibility of bad injectors on the hot side?
Usually this sort of thing is caused by debris in water passages within the motor. I sawed a rotten log in half with the XR4 once, and it took several openings to find all the toothpicks and clean them out.
ufm82
Master Chief Petty Officer
Re: Mercury lemon?
Nice thread title. You have a 3 year old engine, damage it through your own admitted error, have it "fixed", and then run it for two more years in a compromised condition and you say "mercury lemon"??? Laddies has the answer for you.
