Re: Mercruiser 470 3.7L Ive got fuel and spark still wont run
I have not tested compression but i know it has it. If i turn it over with all the plugs in there is a speed difference from when i pull all of the plugs and turn it over.
Wow that's a compression test?
That must be a new way to check it
.... So if it has a dead cylinder it's going to run?:facepalm:
When you change out the wires and plugs you did it one at a time correct?(I guess not since you have had all the plugs out) Some people get the wires all outta whack and then for sure have a starting issue..
BTW go buy a compression gauge.. If you don't wanta purchase one then auto parts store might loan one out (IDK I have always had one)... Do a compression test by advice giving in previous post by Don.. You could have a valve sticking in 2 cylinders.. Guess what.. Won't start like that but will give you the perception that it has compression if you look at the way you see it...
Have you ever seen this engine run?
