Hello all,
I have a 1983 Mercury 90hp Inline 6 that is very hard to start. Once I finally get the motor to start it idles nicely, runs great and starts up every time unless I let it set over night. I am thinking that it may not be choking correctly? It smells like its flooded and the number 2 carb does drip quite a bit of fuel when I sqeeze the primer ball and even for a few minutes after the motor is turned off. Is there any way to find out if it is the choke? Does anyone have an idea on what it might be or does it just need a total carb(s) rebuild . I just recently bought the boat and motor. It has good compression and new plugs. It did set up for a couple of years inside of a garage. Any help will be greatly appreciated.
