I have a 2004 Stingray 190LS. I love this boat except for the porposing. I've read that Smart Tabs will cure this. My question is this...with properly installed and adjusted smart tabs on the boat, will it always run bow down? Or will I still be able to trim my outdrive up and raise the bow while running. The only way to run the boat now is with the trim all the way down. I have a 4 blade SS prop on now. It helps a bit but the minute I get into higher speeds the thing starts to bounce...even in super flat water.
Thanks for the help.
Soggy in Seattle.
Soggy in Seattle.
