1994 225 yamaha cuts out, like a light switch off and on, carb motor
hogwild04
I just got this bass boat, replaced plugs, cleaned gas tank, cleaned carbs, changed filters. I ran it today and mechanic looked into carbs while sputtering and all immulsion tubes were doing the same thing, spit gas then stop for a split second coinsiding with the sputtering, we tried spraying carb cleaner in carbs during sputter and it did nothing. Tried squeezing bulb during sputter w/ no difference. Bulb is not hard during acceleration and you cant make it stay hard while squeezing. you cant squeeze it fast enough to keep up. idles fine and revs fine until your under load.Could it be tps? fuel pumps?
99yam40
Re: 1994 225 yamaha cuts out, like a light switch off and on, carb motor
I would think that monitoring fuel pressure/ vacuum while the problem is happening would give some info
