Re: Cougar235
I wouldn't drill out the jets. That's a brute force method which avoids finding the cause of poor running and just treats the symptom. Do a complete carb teardown and rebuild. Make sure all core plugs are removed, the carb bodies soaked over night in carb cleaner, then blown dry with compressed air, new jets installed, etc. The OEM shop manual provides guidance. Make sure to check the block for air leaks. BTW, does squeezing the primer bulb or activating the primer/choke change anything while at speed? You may have a fuel delivery problem. Has anyone checked the fuel pump output pressure or checked the fuel system for air leaks (cracked tank pickup tube, lose connections/clamp, bad anti-siphon valve, etc. ?
Sorry, just reread your initial post. Yes, 4000 ' MSL is enough for rejetting if you routinely run at that altitude or higher. See the OEM shop manual for the right jets. BTW, jet size is smaller, not bigger at altitude, so one of your 'mechanics' had is backwards. If you rejet, you shouldn't use the motor at sea level or close to it with the same high altitude jets installed.
If you're not going to do it this yourself, sounds like a new mechanic may be needed.
