engine won't shut off
gbb
I have a 86 90 hp Johnson.In the past a couple time the engine would not stop when I turned the key to off. Started it today, it ran fine but everytime I tried to shut it off it keep running. I had to choke it to get it to stop. I got a manual, but I,m not much good at understanding the tests to perform. Can anyone give some advice on this, should I just replace the ignition switch?
SparkieBoat
Re: engine won't shut off
could be switch..you need to check your connections first..make sure all switch connections are tight..and check the ground wire where it connects to engine block after the big red plug under the motor cowl..loose/broken ground is usually the problem..could also be bad ground connection in big red plug..to test for a short..get a 10-15 foot piece of wire..connect to engine ground then connect to key switch ground and test..if problem persist..OHM test key switch..I cannot remember what color the power pack ground wire is but the black is ground and should have no resistance or very very little between black ground connection and the kill connection..
Joe Reeves
(Ignition Kill Circuit)
(J. Reeves)
A Black wire (ground) should lead from the powerhead to the powerpack. There will also be a Black/Yellow wire leading from the powerpack to a raised "M" terminal of the ignition switch. To complete the circuit, there will be a Black wire from the other "M" terminal of the ignition switch to ground.
When the key is in the OFF position = The two "M" terminals are connected,. effectively shorting/killing the ignition.
When the key in ON position = The two "M" terminals are not connected and the ignition is engaged.
milliesdad
Check the connections at the key switch, and the switch itself.
Please let us know what you find, as I have the same motor.
gbb
Thanks guys, It got so dang windy here, I won't be able to check it out till tomorrow. I will let you know how it goes.
Silvertip
Or you can simply disconnect the wires on the two "M" terminals and start the engine. Then connect the two wires. The engine should quit. If it does, the ignition switch is suspect. If it doesn't there is a wiring problem between the switch and the engine. But since the problem seems to be intermittent, repeat the test several times to be sure it is one or the other.
gbb
Looks like the switch is bad. Checked continuity between the m terminals and also checked to ground. The m(ground) was good but not the other M terminal. I am going to rig a kill switch for now, just order a new ignition switch.
